Help oil residue on spark plug threads
Old Nov 14, 2016 | 12:04 AM
TomekEVO's Avatar
So I am fairly positive that these are the original plugs.
Car has low miles, around 60K and I am pretty sure those are the factory plugs.
I put in new plugs and drove around about 500-1000 miles then took them out and there was only a little bit of residue on one of them
Here are the pictures of the original plugs which are supposed to last for about 60K miles
imgur.com/a/uWMTa
Thank you for the input
Old Nov 14, 2016 | 06:23 AM
CaptainSquirts's Avatar
I had a spark plug gasket go bad and oil would leak up into the spark plug valve cover. So maybe it's possible it's normal for spark plug to get some oil on them?
Old Nov 14, 2016 | 02:33 PM
barneyb's Avatar
Plugs look great. Maybe the valve cover is leaking a little.
Old Nov 14, 2016 | 02:46 PM
TomekEVO's Avatar
bump
Old Nov 14, 2016 | 05:33 PM
4b11slayer's Avatar
More then likely Anti Seize was used during assembly. That stuff sticks around a while. Better then a seized plug.
You shouldnt worry, if it were a serious issue of oil consumption you would have a ton of oil ASHES built up down in the center electrode area.
Old Nov 14, 2016 | 05:34 PM
evo.matt's Avatar
do you see anything on top of the piston? Have you ruled out the valve cover gasket? Being 10+ years old already, they could probably use a replacement. http://www.streettunedmotorsports.co...er_gaskets.htm
TheHeist
Feb 20, 2015 07:38 AM
Magrud3r
Sep 25, 2014 06:22 PM
WikdEvo
Nov 8, 2013 08:30 PM
AWDBus
Dec 8, 2011 11:01 PM
QAT-R
Aug 31, 2006 11:05 PM
Quick Reply: Help oil residue on spark plug threads
