Exedy Triple "From pull to push" ?
I have a Exedy Triple Cerametallic Clutch "Pull Style" and I want to convert it to a push style. What parts are need to do this? What part number for the pressure plate? And what Hydraulic Release Bearing would I need to use? Also can them cerametallic clutch disc be used with a push style clutch set up?
you have to buy it from ams because they are the only ones that make the kit to convert it you cant just go buy the parts sep and put it together.
i mean you prob could but its not worth it the kit is like 1500 dollars comes with everything you need to convert it. only thing it might not have it a banjo bolt to an for the brake maser cylinder.
i have the convention on my car and i freaking love it so much better then pull type.
https://www.amsperformance.com/cart/...grade-Kit.html
mchristian
63
Jun 19, 2014 04:49 AM
konstantinosIX
13
Sep 25, 2011 12:51 PM
Celica2EVO
20
Jul 9, 2009 04:07 PM
