Clutch not engaging
Clutch not engaging
Well, i was driving and after a short pull i try to change gear and it wouldnt go into any gear. Then i realize that pressing the clutch pedal is not doing anything at all, so at low rpm i can push into gears, just as driving without clutch. What shouod i look at? Throw out bearing? Bleeding? (The pedal has exactly the same feeling as before).
Sounds more like clutch not disengaging. What clutch?
I'd try bleeding first or look to see that the slave has proper stroke. However, If dual, probably warped, if single, something is broken and jammed between flywheel and pressure plate.
When you push the pedal does the slave cylinder push the release fork? If not you have a problem with the hydrolics, if so its probably either a TOB or pressure plate issue.
Most of the pedal feel comes directly from the pressure plate. So, if pedal feel is normal I gotta think everything down to the pressure plate is normal.
chrisff521
24
May 5, 2012 12:27 PM
TheMadScientist
Sep 26, 2009 11:13 AM
lucky_evo
Jun 29, 2009 05:47 PM
