Crankshaft burn
Crankshaft burn
guys need ur input. There is a slight burn on my crankshaft. Can i still continue to use it?
so far no vibration or weird sound or any debris. Need ur advise. Wat shud i do. The crank cost me a fortune. Its an eagle 94mm crank.
If there wasn't a problem, I don't know if its an issue.. Yeah, it looks like heat build up-- but I would think it would cause the bearing to fail if it was a problem.. As stated earlier--you took this apart because...?
i bought this engine from an engine builder in my area. I saw the car started up and it sounds great which is when i decided to buy it. Every parts in the engine were rather new.
The reason i opened up the crankcase was just to snap pics (excitement of having a fully forged internals) of the internal parts before i decided to transfer the engine to another evo body that i have. This is when i noticed these sort of rainbow burning marks.
The engine builder who sold me the engine said it shud be ok to use as it's just a slight burn and that he had already replaced new bearings,however, i'm still worried and i need advise on what should i do. should i just return it back?
4b11slayer: yes i'm using a twindisk.
