Will an Evo 6 ayc pump fit in an Evo 7?
Hey everyone first time posting here, just curious as my ayc pump in my Evo 7 has shat itself. Found a second hand pump from a 6 and wondering if they are interchangeable? If not is there any way to make it fit?
no as the 7 runs AYC and ACD so evo 6 pump is missing the ACD solenoid..
you need a EU/JP GSR pump from evo 7,8,9 ideally but you can fit a evo X pump with some work.. not a bolt on though...
it would need some adaptation in the harness, but nothing serious (just different connector for the motor and use the 7 short harness on the X pump), and the only issue might me the pressure sensor. IIRC both are the same electrically, apart from the connectors, so using the X sensor might work. Other option is to use the 7 pressure sensor on the X pump but that would need a mechanical adapter because thread is no the same.
in short, doable...
MR1JZ
Jun 12, 2012 12:25 AM
Livefast.eu
13
Apr 8, 2012 01:58 PM
johnnnyjeans
Dec 26, 2011 10:26 PM
