Need Help, ALL 3 ACD Lights on
Recently bought a car and all 3 ACD lights came on
been doing a lot of research but didn't get no where.
i did the paper clip trick and got the following codes
24 Right Left wheel speed sensor
25 Abnormal diameter tyres
26 Vehicle wheel speed sensor system
81 Pump relay open or short circuit
82 Pump malfunction or sensor failure
could this mean i need a new ACD Pump?
Thanks in Advance
Thanks in Advance
Sorry to tell you, but the 3 lights usually means the ACD pump is not producing enough hydraulic pressure or is seized up completely. Hopefully it is just an electrical issue in your case.
If the pump is bad, you can try to fix it by taking it off the car and rebuilding it yourself, or send it to be rebuilt, or buy a used one, because new they are around 2k.
Driving with the 3 lights on is ok, but you lose some of the ACD benefits. The longer you wait to fix it, the harder it will be to rebuild, because it will become even more corroded.
I hope it's not so bad in your case. But for the cars in the rust belt states, the condition of the pump can get pretty bad in some cases.
06MREvo
For Sale - Part Outs
34
Nov 18, 2014 01:05 PM
NOMIEZVR4
Oct 18, 2013 01:28 PM
MarylandEvo
31
Apr 16, 2013 12:06 PM
DubsE46
10
Dec 30, 2011 04:48 PM
