Pressure plate hitting bell housing?
hey guys... was wondering if anyone has experience with this. i was on a long long drive last weekend and forwards the end of it when id step on the gas id hear a knocking/ grinding. sounded near the transmission so i pulled it out and there are grind marks on the pressure plate and bell housing. throw out bearing is destroyed but I'm trying to find out what might have caused this? will post pics later
If the flywheel wasn't loose or pressure plate wasn't loose, that is likely crank walk....
There's a bunch of broken fingers stuck in the back of the bell housing. One probably got wedged between the pressure plate and the housing. Are those fingers missing off of the pressure plate? It looks like your clutch went boom.
Yes they are fingers, but no the clutch didn't go boom. The TOB was so bad and stuck I had to cut the fingers to get the clutch out of the bell housing.
everything was tight... i tried prying the flywheel a bit to see if i could get movement and i couldn't.... you would just think if it was crank walk it would be hitting all the way around the pressure plate not just one section... thats what I'm getting at with the picture
I wouldn't expect the clutch cover, being a stamped part, to be all that dimensionally even around its cirrcumference. Rather, what happened to the clearance between the cover and the bell housing during your trip should be your inquiry. You say no crank walk, no loose flywheel bolts and I assume no loose clutch cover bolts and I also assume no other loose parts or missing clutch disc material moving around in the bell housing. If all that is true then its a mystery to me.
I'd suggest, if you want to investigate this further, bolt on the flywheel and replacement cover, put a thin layer of modeling clay on the cover, mount the transmission and bar the engine.
Chris Smith
Aug 19, 2017 02:12 PM
okevolutionVIII
Jun 13, 2013 04:17 PM
kristian4802
Feb 16, 2012 04:38 AM
Thugline
Apr 2, 2009 11:23 AM
