Perrin fuel rail new setup figment!
Okay guys having some issues here. Just installed my new curt brown racing 70mm intake and 70m s90throttle body. And with fitting in fuel rail it will hit Throttlebody. Anybody ever run into this issue before. Anyone run any other fuel rail. What’s ur opinions
Iposted on the s90 thread also.
i ran into the same issue with a AEM.
I ended up putting a AMS on it and it worked.
An STM will work also because it doesn't have those big flange fittings.
You can run the supply line through the side of the fuel pressure regulator with the other side hooked to the rail. You can then cap off the end by the throttle body, which is what I did. It also keeps a lot of the gas from running through the rail and heating the fuel. I was able to use the throttle body side as the supply before changing to supply from regulator, but I am using the Full Blown 70mm throttle body.
merchomini
Aug 23, 2013 11:53 AM
Boomba Racing
Feb 2, 2012 02:19 PM
ryukinevo
Dec 8, 2010 08:30 AM
turboDan
Oct 16, 2007 05:56 PM
