Crankshaft Stresses 101
once you have w, then w = v/r
easy way to get your vector value (V)....
now that you have the V, you have to calculate your acceleration and deceleration of the rod/piston assembly as it goes up and down.
ill have to think some more on how to do that...
i think its 200 level statics tho.
haha
haha
Let's step this up to 102 first. Hahaha!!
yep.
i would suggest calculate forces on the assembly at a constant state... say 6000 rpms with no other forces (as in no combustion). you can add that later.
so... force on the rod/piston at TDC and BDC = 0
force on the rod/piston is greatest at highest acceleration which is at 90deg past bdc/tdc because this is where vector force of the crank is perpendicular to the crank.
2006EvoIXer (May 15, 2018)
yep.
Let me figure out which parts I'm going to build with and I'll run through some basic calculations
2winscroll brought up a good point in another thread. I need to account for rotational acceleration/deceleration on pistons. For 94mm crank, there is a 5% increase in speed as pistons reach mid point.
Update: theoretical max piston speed already takes into account the crank angles.
That drops my rev limit for 94mm crank from 8,298 rpm to 7,883 rpm. Well that sucks!!
With 153mm rods, rev limit increases to 7,900rpm. Is this extra 17rpm worth $500?
26 m/s is the same as 5,118 fpm. I read somewhere that 26 m/s is target to allow oil to work properly on pistons.
I'm sure it won't fail if you push it higher. The risk is you wear out cross hatch faster. If you have $5k on that race, risk it.
Calculating the limit really surprised me how little advantage 3mm or 6mm long rods really provides. We're better off spending that extra $500 on better designed pistons to counter the wear on walls.
