Help with 450 Fuel pump
Originally Posted by 2Lejit
Not to hi-jack your thread, but since we're on the relative topic... Has anyone actually had issues with a Walbro 450 using the factory wiring, while on e85?
It's a fair question, but if you draw more current from a system that wasn't designed for it longevity will be affected. You can hook it up to the factory wiring and it will run, but it will not work as well as the flow sheet shows. It can also cause your factory wires to run hotter than what was tested by design engineering at Mitsu. My current setup is relay to battery with the relays coil being excited by old fuel pump +. No issues so far. This makes it so that my fuel pump is full throttle all the time, which may not be everyone's cup of tea.
It's a fair question, but if you draw more current from a system that wasn't designed for it, longevity will be affected. You can hook it up to the factory wiring and it will run, but it will not work as well as the flow sheet shows. It can also cause your factory wires to run hotter than what was tested by design engineering at Mitsu. My current setup is relay to battery with the relays coil being excited by old fuel pump hot. No issues so far. This makes it so that my fuel pump is full throttle all the time.
If you drive it and don't get into it, it doesn't seem to have these problems.
New denso 1-step colder plugs gapped to .023
New spoolin up COP kit
New ID1700's
New Fuelab FPR
That's kind of my thought on it as well. This pump was already installed when I bought the car but the factory wiring was used. Maybe it was fine on pump gas but with E85 and 30+psi I feel like this issue I'm having with a misfire, is probably due to low voltage and increased amps in the pump. Just getting too hot maybe.. You can make 1 or 2 hits through a few gears and it runs fine but after that, when you try and roll into it the engine just breaks up. When the fuel level is around 1/4 tank to 1/8th tank it not only does it do this after a few pulls, it also has a 2500ish rpm light misfire under little to no load (just cruising).
New ID1700's
New Fuelab FPR
New ID1700's
New Fuelab FPR
That very well could be the case. I would run an 8 awg minimum cable from the battery to the supply side of a pump relay to keep things consistent. If you have a sound system installed with at least a 4 gauge wire, then your job just got easier because you can tap off that using a distribution block. Just be sure to upgrade the fuse up front. Current doesn't like to flow through long thin wires at all.
I ran straight hardwire for a couple years(due to sheer laziness) with no issues and my pump has lasted. I'm sure I was overheating the fuel though. It's certainly a good idea to run a hi/lo but do you think it's necessary? I opted for a PWM setup anyway so I'm mostly just curious, the 450 doesn't seem to mind running full tilt all the time.
Hey so i have a question about buy the 450 fuel pump. i read a few forums that when u install the 450 fuel pump u have to customize it to fit it to the oem pump holder. like i might to trim a few of the plastic pieces to make the fuel pump fit. is that true. also would i need the rewired kit? Also i want to go E85 and regular fuel. What do i need to make it compatiable? help a brother out. Thanks
So pretty much is this kit a plug and play kit meaning i dont have to cut or trim the fuel pump holder if that make sense.
The kit i plan on getting if i need to rewired it.
https://stmtuned.com/collections/mit...e-deal-evo-4-9
Heres a video on youtube that shows how to modify the fuel pump housing.
https://www.youtube.com/watch?v=PgT_5WdRKA8
1) Spend 5 minutes to vacuum and dust off the fuel hanger cover surface before unbolting it. You don't want to get dirt in your tank by mistake! 5 minutes up front is worth the risk of fishing for dirt in your tank later!
2) Dont snip wires to solder and extend it instead. Keep it 1 piece from pump to connector for each wire. Try removing the clips from connector and swap on the oem connector. As Pal215 found out, heat shrink will fall apart in fuel tank and if you snipped both wires at same length, you risk shorting and will blow your fuse. In general, when solding wires I always cut at different lengths on each wire so they can't short when heatshrinks fail (because exposed wires are at different locations where one wire will always have the original protective plastic coating).
Good video. A few suggestions I have:
