2.5" Screamer Pipe to a 3" Downpipe??
Hi
Is it possible to fit a 2.5 inch screamer pipe (like one below in the picture) to a 3 inch down-pipe?? Is it possible or not at all
The car is a Evo 8 with a stock turbo.
Thanks in Advance
Thanks in Advance
Originally Posted by Jayanaka
What do you mean?? What doesn't need to be big?
Unless that's not what you're asking.
In which case any O2 housing such as what's pictured will work with any down pipe that is meant for the stock O2 housing, which is basically all of them unless it meant for a turbo kit.
Oh sorry if i was not clear. I was talking about the side that connects on to the down pipe. Will i be able to fit a 2.5 inch side onto a 3 inch down pipe?.
The dump tube doesn't need to be 2.5".
ScubaStevo (Nov 21, 2019)
Invidia down pipe
He answered that question already. If it's a stock O2 housing replacement (dump or no dump) it will bolt up to a stock or aftermarket downpipe (2.5" or 3") that's meant to bolt up to the stock O2 housing.
What is your exhaust connected to now?
picked up a external dump pipe but didn’t fit onto my down pipe so this confused the hell out of me because I couldn’t find any that actually fits a 3” downpipe
You would need to replace your existing O2 housing to put an external dump, you can't just slap a pipe on. You would need an O2 housing with a divorced wastegate dump tube, like what's pictured in the first post. Your downpipe will bolt up. If it doesn't you got something strange going on under the front of your car.
yeh I was gna replace my 02 with the external dump
but I would need a 3” outlet to fit a 3” downpipe hey ?
sorryfor the dumb questions but I legit can’t find anyone that sells a 3” outlet for a external dump if they even exist
No, you don't need to find a 3" O2. ANY stock replacement O2 housing will fit ANY stock replacement downpipe. If you're worried about the 2.5" connection from the O2 housing, don't be - the donut gasket that's there fills in the half inch of space when you bolt up the 3" downpipe.
you sir are a legend!
I always thought you’d need a 3” external dump (that replaces my 3” invidia 02 housing to fit the down pipe.
so pretty much the gasket let’s it fit anyway even though it’s a 2.5” outlet
brah. No wonder I couldn’t find any on the market with that size
thank you kindly !
TxFAkuma
Jun 21, 2016 01:53 PM
Gooter
May 4, 2008 07:24 PM
