Evo 5 headgasket
Evo 5 headgasket
Hi! I'm building my motor now. I get oem headgasket but one waterline its not match how its possible? In head all ports match but in block one waterline not. Its that ok? Thanks!
I am also doing a motor build so thought I'd go check to see if mine looked the same and tell you the results.
I have an Evo 8 block, far as I know it has the same oil and coolant passages as a 5.
I went and found the old head gasket that came with the car from the factory to see if it also had a passage that was slightly obstructed.
It does.
If I flip the gasket over...
Turns out a good number of the passages in the block are larger than the holes in the head gasket, and the passages are somewhat obstructed by the head gasket.
Based on this, I believe your engine looks completely normal.
Nebalib (Apr 26, 2020)
Hello Nebalib,
It does.
It does.
FS[Northeast]: 4g63 Longblock, head, and shortblock stock
Evo3573
Sep 30, 2014 08:58 AM
Tim@AMSperformance
Automotosports - Illinois
39
Sep 17, 2009 05:37 PM
fcheng118
22
Jan 18, 2009 11:45 AM
EpicEVO
22
May 15, 2008 08:17 PM
