Act New Twin Disk Who Running One?
#227
ACT is going to warranty the floater/clutch. ACT said this issue is happening on the early release where the tension fingers/clips(located on the floater plates) are breaking due to manufacture defects. They mentioned something about the metal grain and stamping orientation not being correct with the tension fingers/clips.
I did notice the tension fingers/clips are wearing into the flywheel. ACT said this is normal for the tension fingers/clips to wear into the flywheel and the floater plate should be rotated on every rebuild until it can't be rotated again. Once the floater can't be rotated anymore, the flywheel needs to be resurfaced or replaced.
The following 2 users liked this post by blackline:
DontStopMe (Jul 12, 2024),
rustykan (Jul 10, 2024)
#228
Well, I got the clutch installed and now the yellow pressure plate is running on something inside the trans. Also getting a lot of chatter when depressing the clutch. I can feel the rattling through the clutch pedal while depressing the pedal. Going to give act a call on Monday.
#233
I was convinced this is the perfect clutch for me, but after seeing all of the issues in the latter half of this thread, there is no way I am taking the risk. If anyone else relates to this, I would suggest looking here:
https://www.evolutionm.net/forums/ev...ns-review.html
It seems like the XClutch twin is what we all hoped the ACT twin would be: streetable organic disks, high torque capacity, minimal chatter, well priced, etc. I just ordered the XKMI23522-2A yesterday.
5LEEPERISAH23I
78
Dec 23, 2022 12:53 AM
Dolfandrus
10
Sep 12, 2011 08:05 PM
RaysEvoX
14
Mar 31, 2011 10:38 AM
dank311
13
Apr 10, 2008 02:16 PM
