Hard boost leak (with Video)
Hi
i finnally make a boost leak testing on my car and i realized the problem is bigger than i thought.
i made a video about:
i was alone so while i pumped the system with compressor i put down the phone.
the leak is coming somewhere under the intake manifold or the bottom side of it if i hearing good.
i used soapy water and sprayed everything , and the common spots like throttle body and injectors area are empty i cant notice a simple bubble anywhere.
any tip where it comes?
the air i compress in ,immediately leaking out somewhere i cant pump the system to 0.5 bar.
Secondary leak
I found the main leaking behind the intake manifold it was a cracked solenoid plastic pipe. I solved the problem.
but i found a secondary leak at the throttle body. What u thinking i need for solve this problem?
Video:
Video:
Darkn3s
May 1, 2011 03:54 PM
era-teknic.com
Nov 17, 2006 05:35 PM
