Extremely laggy turbo
Ok so I'm a bit stumped here. Freshly rebuild motor only 170 miles. I went from a internally gated to external gated setup. I think the issue lies with the wastegate.
So got my car tuned on a fresh rebuild and new turbo setup. Went from a 71hta to a fp black. Compression and leak down test were good. The car isn't boosting till 5 to 6k rpm. Did a boost leak test and and 3 small leaks on wastegate and one small leak on intake where pcv connects. I fixed all leaks and still 0 boost till 5 to 6k rpm. At idle theres no exhaust gases or anything coming out wastegate dump tube. Wastegate is set at 18.85psi springs, currently tuned on 19/20 psi for break-in reasons.
Current setup is a fp black with the ss housing with a tial mvs 38mm wastegate and fp cast O2 housing and a fp manifold. Running the grimmspeed ebc. My previous setup there was no issues what so ever.
Motor rebuild was just new rings and bearings, fresh hone and valve job with new guides. So I'm stuck on what's going on. I feel its wastegate related but I see nothing wrong with it. I know I didn't have to struggle mounting it so maybe something installed backwards?
Just to summarize: You have a not stroked/non-mivec engine, and you went from a twin scroll 71hta to a single scroll FP black. I'm not trying to be critical or anything, but I wonder if this could be more of an expectations management problem vs. a mechanical one? Was there some example build you were going off of that you are falling short of, or have you talked to FP about what to expect vs. where you're at?
What cams are you running?
Yes the seat is installed and in correctly
I'm running kelford 272
Its a built motor nothing changed from previous setup motor wise. Just upgraded fuel and turbo setup.
What about in higher gear like 3rd to 5th gear?
Its every gear
As for other that mentioned twin scroll and single scroll, would that really be that big of a difference? Its not a massive turbo. It is a twin scroll manifold to single scroll turbo, so maybe thay plays some factor?
with running wastegate off compressor its seeing boost right around 4k. Turbo definitely isn't toast, or at least better not be it's all brand new. I may have not researched enough, seems it's common to spool around 4k to 4500 rpms with the black. I'm gonna try running the boost controller with the 3rd port hooked up to the intake pipe and see if it has same result with hooking it straight to compressor.
