can you change rod bearing without taking the engine apart?
i want to switch to a baffled oil pan like the one from JUN(buscher has a oem looking one too but those yanks dont want money apperantly)
i might aswel do the rod bearings(oem bearings dont need anything fancy) while im doing that job so is it possible to do?
I know that they became a maintenance item on the 10 cylinder BMW M5 due to a design flaw (improper factory clearance)
If the engine is running fine without any signs of metal shavings (or rod knock), there is no need to replace those bearings.
^ Agree wholeheartedly. At 116k miles with 11 track events, my bearings were all still in perfect shape.
If you have good reason to suspect a problem, i'd start with some non invasive testing:
1) Used oil analysis
2) Oil filter autopsy
The OEM bearings have 3 or 4 different sizes. You would have to take your bearings out to see what you have and order replacements.
But like others have said, it is an unnecessary repair that could actually cause an issue where there isn't one.
Agreed with the above. The 4G63 has proper bearing clearance and oiling, so they are not a routine maintenance item. If you rebuild the whole engine or spin one, sure, but high mileage is not going to guarantee that you need replacements. Essentially they’re fine until they fail in a big way, and you can’t prepare for that. You hear about precautionary bearing replacement on stuff like BMW’s M E46/E92 M3 engines and V10 M5 engines because the clearance was tighter than it should have been, so premature wear is absolutely a concern there. If you’re really concerned, drop a rod cap and inspect one, but I doubt you’ll see anything catastrophic.
Aby@MIL.SPEC
Sep 23, 2005 11:37 AM
