boost?
boost?
i just installed my boost guage and im getting about 17psi then it tappers down when i hit higher rpm's is this normal? also will a mbc fix it and will i be able to hold the same psi all the time? any help will be appreciated cuz i hate the feeling of losing the boost.
Make sure that your clamps around the BOV are tight. Alot of people including mine were not tight. But be carefull not strip them out. After I cranked mine down the boost taper was not as drastic.
