Exedy Triple Slight drag when warm?
Hey everyone,
I recently picked up a built Evo 8 with an exedy Triple in it. I've recently noticed when I put the car into reverse, it wants to creep backwards even with the clutch fully in. Revving slightly does not seem to increase it much, if it all.
Car has 2 step enabled so I haven't been able to rev it past about 5000rpm to test it. It also seems to want to creep slightly in first, but not as bad if it all. Honestly it's hard to tell.
I haven't had any lockout issues, but that's probably attributed to the dog box in the car. I have yet to see if the master needs to be adjusted, but it was adjusted last year to my knowledge. Clutch bite point is pretty high, about half way up the pedal travel if not higher.
Also, this seems to happen once the clutches have warmed up, as it does not do it at all when its cold.
Any insight before I pull out the master cylinder and try to adjust it? Anyone have a similar experience? Thanks I'm advance!
Hey everyone,
The master was already adjusted pretty far out, tried a few more turns to only 1 or 2 threads left outside the bracket, no improvement.
Any thoughts or insight?
Sluik (Jun 27, 2024)
The center hub is probably worn. Need to pull the trans and inspect the hub and discs. Likely needs them replaced if it has miles on it.
memphis raynes
Mar 20, 2016 06:22 AM
Silver-IXse
16
Jun 12, 2014 07:53 AM
Turbo01s2k
Mar 14, 2010 06:15 PM
