Correct gear oil for 5 speed
I'm having a lot of trouble getting a straight answer from shops about which gear oil to use in my evo 7 5 speed transmission
I've been told I must use GL5, I've been told I must not use GL5. I've been told I need the motul 300 LS, and not the motul 300. Then other places have told me I must use the 300 and not the 300 LS. I've called all the shops that claim to be evo experts and none of them seem to be able to agree on the correct response
Amsoil is one I see mentioned on this forum a lot. But it's fairly rare in my country, so no shops will comment on the correct type.
Can anyone confirm for me if this particular amsoil is the correct one for me to buy ?
https://www.ebay.com.au/itm/25601032...Bk9SR4j9y7KuZA
It doesn't mention anywhere if it's GL4 or GL5
This one appears to be the same oil with a different label, but is significantly more expensive.
Yes I realise it's 2 bottles not just 1 bottle like the other add. But is still a lot more per bottle and the shipping is 4 times the price
https://www.ebay.com.au/itm/12614753...Bk9SR4b9y7KuZA
gear 300 75W90... NOT LS
gear 300 LS is for the transfer box and rear diff (RS) or input ring and pinion part of the AYC DIFF
Motul Gear 300 75w90
Or Red Line 75w90NS
Or Red Line 75w90NS
thepoint4life23 (Aug 26, 2024)
Shock proof doesn't go in the trans. The dissolved solids will get centrifuged out of solution inside the shafts and clog stuff.
boosted2x2
Sep 3, 2014 12:21 PM
Jaded-7
Sep 27, 2011 07:10 AM
