Fault code: P0710
Fault code: P0710
Hey,
After swapping from 6 to 5 speed in my IX, ive gotten the fault code P0710, indicating transmission fluid temp sensor - circuit malfunction. Also i have a yellow check engine light.
As far as im aware neither the 5 or the 6 speed got a transmission temp sensor, and i have not seen anyone else getting this problem, even tough hundreds on this forum have done this swap.
Any suggestions?
Edit: i did indeed find a oil temp sensor on the 6 speed i swapped out..
Any suggestions?
UnholyMaggot
Jul 23, 2016 09:32 PM
