Why is my car destroying Coil Packs?
Old Aug 22, 2004, 06:29 AM
MalibuJack's Avatar
If I remember the information from way back with the Emanage, or any aftermarket ignition "driver" The damage isn't caused by the engine running, but how the coils arent "discharged" when the engine isn't running so it burns up the primary in the coil pack since their energized when the ignition is turned on, but the car isn't running.
If you make a habit of not turning the key on for long periods of time with the engine not running, its likely you wouldn't immediately burn up the coils.. If you find your doing alot of tuning and tweaking, you may end up turning on the ignition without starting the engine.. I think that is what is damaging the coil packs.
Another post talked about the output level and the switching voltage required for the ignitor to energize the packs, and the Emanage may produce output that is just above that switching threshold.
You can always swap to afermarket coilpacks and ignitors...
Sicktght311
Lancer Aftermarket Forced Induction Tech
42
Mar 30, 2018 01:13 AM
mikepulley
Jul 25, 2017 01:56 PM
11secEVO7
14
Feb 23, 2017 11:27 AM
Nniikkooss
13
Jun 30, 2016 08:27 AM
Rossi_24
May 21, 2016 09:09 AM
Quick Reply: Why is my car destroying Coil Packs?
