Why is my car destroying Coil Packs?
I went through like 4 coil packs in the last week.Checked through the electrical system and everything seems to be fine.
I was told that it could be the emanage that I have. I recently put it in...thing is that when it went in...everything went fine for like 2weeks straight.then after that it started melting coils every other day.
I updated the software and everything on it.Could it still be the e-manage?
thinking about taking it out to see if it will still happen....but after paying $200 to have it installed...i would have to pay another $200 if I take it out and put it back.
could anyone give me any other ideas as to what it might be?
i think so too.
If I were to just disconnect the ignition harness from the emanage......I was thinking of doin this since i dont really want to disconnect the entire thing.that would be last resort.
992gnt....i'll try that asap.
i think so too.
I was going to ask you if you had the ignition harness hooked up......you awnsered my question.....I am pretty sure that whats causing it. Just disconnect that. I had the same problem with my mazda...the ignition harness kept frying packs.
Check out AMS website, They say on there site that the ignition harness fries the coil packs and that they will not sell them for that reason. I'm sure thats what your problem is.
Originally Posted by evosevengsr
Car fanatic...I think so too.
I will check the grounding and perhaps purchase a grounding kit.
The factory grounding will more than likely be secure. Its the design thats inadequate.... leading to the coil having to work too hard to produce a spark, especially in higher than stock cylinder pressures.
You can make you own grounding kit out of 4ga AMP wire, consult the how-to section for fitting and building advice.
you see...it's all been trial and error so far because no one down here seems to know what it is.Everytime I think it is fixed it melts again and we try something else.now it's down to the emanage or as Jemm said..grounding.
If it's the emanage,then i definitely regret buying it.the amount of money i spent on coil packs alone..i could have bought a proper management system..
stress!!!!!!!
stress!!!!!!!
