2nd Blown Motor Blown Clutch 3000 miles sucks
Old May 13, 2004 | 03:05 PM
  #31
OnlineAlias's Avatar
Clutch went out at 500 miles? You were racing it? AT 500 MILES? Break in, anyone?
I can't believe they fixed the first motor....
Old May 13, 2004 | 03:13 PM
  #32
racerferrari's Avatar
na na it was actually about 750 to 1000 miles the snap ring went and the dealer replaced it with an aftermarket clutch for me
Old May 13, 2004 | 03:16 PM
  #33
ThomBlazeEVO8's Avatar
Yep, I feel you man...check out my story...
I gotta long running thread at DCEvoClub Here about this which has now resulted in a local boycott thread...
Short story, my no. 3 rod bearing failed at about 14,500 miles. Local dealer replaced shortblock. about 1000 miles later and just two weeks out of the shop from the first replacement, my no. 4 rod bearing fails. Dealers says kiss off, Mistsu says kiss off...took it to arbitration...they say kiss off. Dealer pulled out a xerox copy of pics they took of my clutch (from the first repair) and said some hot spots on my clutch indicated over rev abuse and clutch slip. Arbitrator bought since I wasn't techical and I had the DM with his proclaimed 4 year auto engineering degree, the dealer ASE guy (lying on me mind you) and the service manager all stacked against. DM also lies to arbitrator and says he's never seen that on an evo.
Turns out another local dealer who reports to this same DM has a Evo on their lot that had a rod bearing failure and then a the turbo failed. They guy who owns was so upset that he dropped the car off (yes, he was fortunate enough to the the second repair because his dealer fought for him) at the dealer and said screw it. He doesn't want it and is going to allow it to get repossessed. I found all of this out after my arbitration.
Whatever the case, my Evo is 7 months old, I'm still paying on, has be inoperable for almost 3 months and my local dealer is tell customers that I modded my car and admitted I abused it.
My car is stock, I've never tracked or raced it. I know they are spreading lies because a couple of our local club guys were told that directly by the dealer when they inquired anonymously.
I'm looking to find someone who can give me a new motor at a reasonable price now. Any leads or ideas people, let me know. I did have a PM in to Big Al but I've not heard back from him yet on a parts and labor package in total.
Best of luck to you man...I can't afford a costly litigation right now (I've already consulted with my attorney). It will be cheaper for me to work on getting the car fixed.
Regards,
ThomBlaze
Originally Posted by racerferrari
my codriver a Porsche mechanic/driver for years and he said if they didn't flush out the oil pump......the contamination would reflow thru the system....geez the second motor only had 700 miles on it and for those guys that had mentioned about break in.....first the clutch was a snap ring failure......it actuall think it was around 750 miles to 1000 miles...i broke in the car the correct way everytime...600 miles each time....anyways...they sent the head out when they rebuilt the motor and got it checked and cleaned up....they blamed the silicone from the oil pan clogging the oil return for the first failure....and i'm almost positive they didn't flush out the oil cooler...but it was a short block replacement...and they did send the head out to be checked....dealer don't know much...they are pretty much part replacers....when the original motor went....there was a knocking....they couldn't figure out what was wrong...so they first replaced the crank bearings...didn't fix....they they pulled the head off of the car and #1 cylinder spark plug head was blow completly blown off(thats the first thing the should have pulled is the spark plugs)...so they sent the head out to be checked.....they put the head back on...still knocking....then they did the short block....after replacing those 2 things.....i know this for sure because i stopped by the dealer every day..sometimes twice a day checking...because i wasn't working at the time....anyways...anybody have any suggestions on what i should do now....i could sue them...but it cost money...what will i get....i'm not sure what it will cost...$2K...3K....i could probably get it all fixed for that....suggestions any????
Old May 13, 2004 | 05:35 PM
  #34
GOKOU's Avatar
Originally Posted by Captain EVO
I can't blame Mitsu for not repairing your engine again. I would'nt either. That is the risk we take with modding our cars and racing. We all complain about Mitsu going bankrupt and such, but we are part of the problem, not the solution. When we mod our cars, we are basically taking the risk of losing the warranty. If we race, we guarantee that we are giving up our rights under the warranty.
By the looks of the other vehicles you drive, repairing your engine to make it better than before will hardly be a drain on your pocketbook
Good luck,
CPT EVO from Iraq
I don't agree with your statement. The car is stock. What the hell did Mit expect out of this car. grandma and grandpa riding it. Make it idiot prove. I guess they didn't beat the crap out of their US protype to find out these issues sooner. If you want to do something, do it right or else do don't it at all. There are plenty of small things that MIT could have done to make this car better and save them from all these complaints. Just not worth it. This is whats making them bankrupt. With all the problems with the 1 and 2 gen DSM they should have realize something by now. If they can't make more reliable AWD car then get out of that business. This is my 1st and last Mit.
Don't get me wrong. I agree that some of these issue is definitely the driver's fault but when it happens at low mileage and with different people it needs to be flag.
Old May 13, 2004 | 07:41 PM
  #35
Coolguy949's Avatar
Wayne, I think I know what your problem is. At Thunder Hill I saw a black cat walk past your Evo.
Good luck!!
Old May 14, 2004 | 06:09 AM
  #36
ogvw's Avatar
Wayne.......... that sucks about your second motor. Heres my take - Racetracks are bad places for street cars ( even though I love them and take my car to the track on a regular basis ). The stresses put on your car at the track are beyond what the car will ever see on the street. Im not saying that there was nothing wrong with the rebuild your dealer gave ya but at some point you have to cut your losses at the dealer and get a real motor. If my motor blows up (knock on wood) Id skip the dealer and go to a pro.
kev2nice
Nov 11, 2011 06:31 AM
Graphite_MR
31
Dec 3, 2009 07:21 PM
Arithmetic
56
Nov 20, 2005 12:25 AM
racerferrari
May 19, 2004 05:49 PM
racerferrari
Apr 15, 2004 03:00 AM
