Car starts and idles, but breaks up BAD!!!
Alright, I installed my Walbro pump and got the car up and running, ran it for about an hour and the car worked perfect.
Started up later that night, started and idled perfect, but as soon as you gave it gas it started breaking up (sputtering and backfiring, like it was pulling timing)
Thought it was the pump so I put the stock back in. Guess what? The problem still there, It starts and idles perfect, even runs great under - vacuum, but as soon as boost builds it breaks up bad!
Have reset ECU, check for blown IC hoses, and replaced plugs and fuel pump?
NEED TO GET THE CAR BACK ON THE ROAD!
+ boosts between 2-4psi, but this is sitting at idle. When driving partial throttle boost hits between 6-8psi then breaks up bad! Reading from an E-01.
No CEL, no smoke, just falls flat on its face and sputters. Check the connection a couple of times and reinstalled, If I pull it out again I think I will get drain bamage from the fumes!.
and austin i was just wondering if you didnt melt your cat. my friend melted his cat after installing a pump, his car was runnign extrmely rich and it overheated the cat. im trying to figure a reason why your car would run fine for an hour and then have this problem, changing the pump caused something else to fail. and if changing the pump is all you did. then im just guessin, and that was my first guess, if while holding the engine to 2500 rpm while sitting there if the vacuum does return to what it is at idle or alittle more, id take a look at your cat.
