5th Gear Grind???
5th Gear Grind???
Ok...just in the last few weeks I have noticed when I get on it...and shift into 5th, it does a quick grind in. Almost as if the clutch isn't depressed all the way in. Is this the infamous 5th Gear Grind everyone talks about? It seems to only happen after I got on it some. Never happens at normal shifting and normal speeds.
If so...
Anyone know of a GOOD
dealer in the Northern IL or Southern WI area that is trust worthy to work on it and NOT deny me because I have a couple of basic mods (intake, MBC, 3" TB Exhaust)??? Also...I do still have the 1-2 grind at higher RPMs...I'll need that done too.
If so...
![Help Me](https://www.evolutionm.net/forums/images/smilies/help.gif)
![Mitsubishi Logo](https://www.evolutionm.net/forums/images/smilies/mitsu_logo.gif)
Yep
I also had the 5 gear grind, it continually got worse as my OEM clutch went to ****. I just purchased a Hyper Exedy clutch and have not had the quick grinding sound since. Basically the OEM clutch sucks ballz
I had the 4th gear grind and after i got ridicuously bad they finally fixed it with new synchros. I shift so slow into 5th that I feel it would be impossible to mess that synchro up. After 4th gear fifth my car has pulled all i need and 5th is for cruising. I guess i have never had the need to do a high rpm shift into 5th on a regular basis but I have to admit after getting the new synchros 5th is a lil harder to get in gear. Good luck and take it to Mitsu and let a rep drive it with you in the car and maybe they will get it fixed.
Originally Posted by rebelzx
There's a TSB out on it. Take it to any
stealership and they should fix it for you.
What is a TSB? I have the 5th gear grind as well. I have also heard that there is a special transmission fliud that will stop this and help ease all shifts. Lancershop.com sells it for like 30.00...
yeah...mitsu of Crystal Lake is mod friendly. I have full exhaust, intake, safc, and others. they have not said a word about it.
they are located at rt.31 and rt 176 in C.L.
tx: 815-459-9000
tx: 815-459-9000
Yes.. TSB is a technical service bulletin.. Its NOT a recall, but they are aware that some cars have an issue..
The TSB is specific to 5th/Reverse selector fork, and its synchro.. under certain circumstances the fork gets distorted, in turn it damages the synchro and you get the grind.. sometimes its due to a missed shift or a forced shift into 5th.. other times it happens for no reason whatsoever. HOWEVER according to the documentation that my dealer showed me.. Its a KNOWN issue that is only serviced if the owner complains about it.. and it is covered under your warranty. There are two revised parts for the transmission that will fix this problem.
I do also notice that the selectors in ALL of the gears gets out of whack after awhile (they either bend or get distorted with hard shifting or if the shifter jams and you force it) and they have to be readjusted.
All I can say is this isn't really a "Mod issue" but as a rule of thumb, we as Evo owners should ONLY deal with mod friendly dealerships, this will force the others to eventually become mod friendly.
but DEFINITELY go have it serviced.. it will only get worse.. a 5th gear grind is generally not an abuse issue, and will not generally be viewed as such.
Oh, and no matter what others say, this issue has NO correlation to the Clutch.. the reason the issue shows more, then goes away with a new clutch is the wear on the clutch (usually the throwout bearing or fork pivot ball) becomes misaligned an no longer fully disengages the clutch.. replacing the clutch means replacing the pilot bearing, the throwout bearing, and readjusting the pivot and fork (the hydraulic system is self adjusting so it takes care of itself) but it will eventually come back if its grinding due to synchro wear, and 5th gear synchro wear is a result of one of two things.. a missed shift grinding the cogs off the synchro, or the selector fork and gate are allowing the synchro to grind when not fully engaged.
yes, you will be lucky to have it back in a week. My Evo was given to the dealership 3 weeks ago. They got the parts in on saturday. They advised me they would begin the work today. After speaking to them on the phone, they advised they will begin working tomorrow. NOW I AM PISSED!
