overboosting: manual boost controller...need help
installed a buschur manual boost controller today as per instruction sent by buschur and I'm spiking to 1.6 bar and holding steady at 1.5 bar. Don't know why its doing this. Adjusted to the knob at its highest poiint and still doing this...Any idea whats wrong?
Some mods will cause your boost to spike, such as a turbo-back exhaust. A manual boost controller can only control boost to a certain point. Example: if your car spikes to 20-21 psi before controller was installed it can only be used to go from that point on up. An EBC can be used to actually lower the boost to the desired level and hold it versus a manual which only goes as low as your highest spike and hold it steady. Hope this helps.
Shane
Shane
Shane
Shane
My guess is that you may have gotten a faulty one. Contact Buschur I'm sure they will help you out.
I think what he is saying is the manual boost controller will only hold one point and then things can flucuate. with the electronic boost controller is can accually adjust up and down to maintain your boost more constant. read around alot better control is seen with the HKS EVC than any MBC. IMO
is the ball suppose to come loose when you shake the boost controller? because I shook it and the ball won't come loose. I even took the spring out and it spike to 1.6 bar. I guess I'm going to have to call buschur.
1.6 is 23.20 psi
the ball is supposed to shake inside the controller when its backed off al the way
i was gonna say maybe you have a torn vaccume line ro something but its prolly rhe controller
the stock wastegate acuator goes off around 11 psi so if it was backed off it should go much higher then like 13 psi
FS[Northeast]: Buschur manual boost controller $40.00 shipped
17579EVO9MR
Feb 20, 2017 03:46 PM
RedLanEVO
15
Jan 27, 2009 07:00 PM
tsitalon1
Mar 12, 2008 08:12 AM
jinhaingEVO
11
Aug 6, 2006 08:41 AM
