Removed HKS EVC = Not boosting past 10.5psi
Old Jun 2, 2004, 05:45 PM
Shahul X's Avatar
please help..... its not electrical apparently....... most people are saying its probably not the Wastegate
-shahul
Old Jun 2, 2004, 05:54 PM
93h22cvc's Avatar
the hks boost controller is a major pos. i have seen plenty just go bad with a perfect install out of no where. the evc iv is definately not as good as the ez
Old Jun 2, 2004, 06:22 PM
Shahul X's Avatar
its an evc v and its removed......
-shahul
Old Jun 2, 2004, 06:25 PM
93h22cvc's Avatar
sorry i meant evc v
Old Jun 2, 2004, 06:28 PM
evodave's Avatar
Location: driving the 10 second beast in ohio or running lightmods.net
the mbc will fix the problem...you are riding on the stock spring....just get a manual
Old Jun 2, 2004, 06:35 PM
Mach V Dan's Avatar
Okay, here are two simple tests that ANYONE can use to try to isolate boost problems.
If you are not making enough boost, try test number one.
If you are making too much boost, try test number two.
Test #1: Remove the vacuum hose completely from the wastegate actuator. Leave it dangling. (CAUTION! This can be dangerous to your engine, depending on the car and how much boost your turbo will make.) Carefully drive in second gear and get on the throttle. Watch your boost gauge, and let off the gas before the boost gets dangerously high! 18-20 psi should be enough to let you know the turbo and wastegate works, but not so much you blow up your motor. If the car makes lots of boost, your wastegate and turbo is in good shape and the problem is in the control circuit.
If the car won't make substantial boost, you have one of the following problems:
- Your wastegate actuator is broken
- The actuator arm is not attached to the wastegate flapper
- Something has jammed the wastegate open (I've seen gaskets get stuck in there)
- The turbo bearings are shot
- You have a pretty major leak in the intake system (this usually is obvious without doing this test)
Test #2: If you are making TOO MUCH boost, try taking a short vacuum line DIRECTLY from the turbo compressor outlet to the wastegate actuator. (Make sure it's NOT a factory line with any kind of restrictor in it. A spare chunk of vacuum hose is best.) Bypass ALL the boost control stuff. Even with full throttle, you should get the MINIMUM boost level for your turbo -- usually around 10 psi for DSM's, I dunno what it will be for Evos. If you do get a low, steady boost level, your wastegate system is working fine, and your overboost problem has to do with your control circuit.
If you do NOT get a low boost level, but still have uncontrolled boost, you have one of the following problems:
- Wastegate flapper jammed closed
- Wastegate actuator damaged and jamming flapper closed
Remember, if you do Test #1 and let your car boost to 30 psi, I guarantee it'll grenade, so don't blame me if that happens. But these simple tests can really narrow down the troubleshooting around this issue.
Good luck,
Dan
Mach V
MachEVO.com
Old Jun 2, 2004, 06:52 PM
Shahul X's Avatar
hmm.... not comfortable doing test #1 myself....so yea, I'll see you tommarow.... thanks Dan
-shahul
Old Jun 2, 2004, 09:44 PM
fimotorsports's Avatar
is there a restrictor pill in the stock line? If so make sure its put in the stock location
Old Jun 3, 2004, 06:08 AM
M.A.S.'s Avatar
I have also had this problem. I was running an AMS mbc then put it back to stock. I did not use the stock lines with the restrictors on it, I just used regular vacuum lines. I was told that if the stock lines are not used, you will only boost 11psi(which is what I'm boosting now).
Old Jun 3, 2004, 06:25 AM
AMSTuning.com's Avatar
Sounds like Bin-Bin-Bingo! The stock lines with restrictors have been removed in favor of oversized "GIANT" blue hoses. I think we have a winner here.
Old Jun 3, 2004, 09:46 AM
eLiTe eVo's Avatar
ah good stuff, hopefully that was ur problem and u can get it taken care of >;]
Old Jun 3, 2004, 10:49 AM
Shahul X's Avatar
we shall find out tommarow.... cross those fingers.....
-shahul
Old Jun 3, 2004, 03:40 PM
LateSleeper's Avatar
Try switching the vacuum lines to your actuator and turbo. You may have them reveresed.
Old Jun 3, 2004, 05:11 PM
smc20g's Avatar
Right, make sure you're running the restrictors. I had the same problem where I had swapped out the stock lines. I had put the restrictor that is by the solenoid back, but not the restrictor down by the turbo itself. I was only able to boost 11psi as well until I had both restrictors in place.
Old Jun 3, 2004, 05:16 PM
there is 2 restrictor pills, that's interesting.
Quick Reply: Removed HKS EVC = Not boosting past 10.5psi
