Clutch pedal question...
is there anyway i can adjust the pedal so that the clutch engages lower in the push of the pedal.. It's like I just start to engage with the last 2 inches of pedal....
Yes! follow the clutch all the way up to where it meets the clutch master cylinder. U will see the pushrod and a locking nut. 12mm. loosen the locking nut an turn the rod and make the pedal closer to the floor. turn a lil at a time, drive it and readjust as needed.
yeah, follow the clutch pedal up. kinda tight. need flashlight too. Trust me, not hard at all. don't be too greedy and adjust to 2" of travel for you will grind gears when you try to shift too fast.
it won't turn.. that gold nut seems to be part of the peice that connects to the pedal.. like i have to pull the bolt out and completly twist the part around.... i just can't get that ghetto coder pin out...
the nut that you have to loosen is on the rod itself. not the one with the cotter pin. further down past the cotter pin tingi, you will see the nut on the rod. if you put an open end wrench on it, you will have to push it towards the outside of the car, not towards the middle of the car.
Sorry but that will only adjust the free play on the clutch. The engagement point will remain the same. I don't think you can adjust the clutch to engage lower then it is.
i pulled the coder pin and spun the thing half a turn... it move the part up top about 1/8" maybe a little less but the pedal is now def. lower and I like it... it seems to drive fine too.. so.. did i do something bad???
Once you loosen the locking nut on the pushrod, pinch the pushrod like you are using a Q-tip and then turn it, bring the pedal closer to the floor. Don't forget to tighten the locking nut.
You are adjusting from within the car. it simply reduces the pedal travel of the clutch pedal. this in turn will allow the clutch to catch sooner as you release the clutch. It has nothing to do with synchros. The grinding is simply due to insufficient clutch release due to over adjustment. Meaning too close to the floor.
