Heat Shield for Oil Pan, w/downpipe
Most likely it is the ThermoTec material. After a month or so the fiberglass will separate from the adhesive layer leaving a plastic material stuck to your oil pan (or whatever you stick it to.)
Basically either get a down pipe that has sufficient room between the pipe and the oil pan or coat the pipe.
Why not wrap it? It will help keep the heat in witch will in turn keep the velocity of the gas higher. Keeping the velocity higher will help flow thru the cat. I wrapped mine with the kit from DEI and then painted it with thier silicone spray to protect the wrap.
According to Dave (Buschur) there it is not a problem to wrap it but it may not be the case. I guess if I were going to trust anybody he would be one.
am I alone
To clarify, the shield is a stick on foil type sheet that is about an eighth of an inch thick. It sticks directly to the oil pan and helps shield some heat from the downpipe that is close by. There's nothing to warantee.
Al foil, glue, fiberglass mat, glue, plastic sheet, glue
Does this match what you have or is it something different? (read should we all go off and buy what you have?)
Note that with the ThermoTec material, the fiberglass mat / plastic sheet interface is what lets go. This suggests that the Al foil reflects more heat than is transferred off of the pan. I expected the AL foil / fiberglass mat to go first, that is if anything failed.
[WTB] Hood heat shield
Mike-Who
Nov 22, 2015 05:05 AM
Sheasta
Aug 9, 2015 07:50 PM
CeliOnce
Jul 27, 2015 11:46 AM
