Clutch slipping Question ???
Old Jun 25, 2004 | 08:31 AM
Noize's Avatar
EvoM Administrator
Mine realease way up top too. Just enjoy the car, man. If you're getting slippage, then its time to take action. I think your clutch is totally fine.
Old Jun 25, 2004 | 08:36 AM
superz's Avatar
Originally Posted by Noize
You obviously know ZERO about how a clutch works. Stop scaring this guy with your total lack of knowledge. Any manual car will creep forward if you let the clutch out without throttle unless your idle is so low that the motor doesn't make enough torque at that rev range to pull the car, hence stalling. This isn't the case with the Evo. Learn something about cars before you make goofy posts like this in the future and totally embarrass yourself.
Gokou, your car is fine. Stop sweatin' it and drive. If you go WOT from ~4000rpm while in gear and your car revs freely like you were in neutral, THEN you'd have a slipping clutch.
Ok, you know better . Im wrong
Old Jun 25, 2004 | 10:18 AM
Noize's Avatar
EvoM Administrator
Lightbulb
Yes and yes.
Firm
Jan 21, 2012 01:31 AM
flymx771
11
Sep 24, 2010 04:20 PM
mrdecrypter
14
Apr 8, 2009 02:42 PM
4myX
Jun 18, 2008 07:45 AM
xxxevo8xxx
Sep 16, 2005 09:10 PM
Quick Reply: Clutch slipping Question ???
