having major drivetrain problems
i had the same problem last weekend heading up to the st. iggy cruise in michigan. the car would out of nowhere shake and rumble, when i let off it would stop, but when i started to step into it it would get worse. not to mention when i stepped into it on the freeway, i wasn't watching my speed, but the state police on the side of the road was, i got knicked for 93 in a 70 zone. my car hasn't did it since, and it never did it under heavy acceration. i think i ll be doing a comp. test and plug check first thing tomorrow. thanks for the tread and the help
Originally Posted by Secret Chimp
Sounds like the 0300 cel Random Misfire plaguing some Evos....including mine. Have you had your cel checked?
SC~
SC~
Originally Posted by evo 8 ya
If you have your car reflashed by a vender of your liking (I went with dynoflash) you won't get that code any more.
Most of the Vendors have backed away from their claims that their reflashes erase the occurrance of the 0300 random misfire. Most will at most commit to their flash only reducing the number of occurrances these days. So don't bet on it curing anything.
The random misfire is caused by an overly sensitive knock sensor/program. The sensor hears road noise and other harmonics created by the car on a freeway, it improperly transmits those road noises to the ecu as engine knock....then your ecu compensates for what it believes is very harmful engine knocking in an attempt to keep your engine from grenading. That is the misfiring/studdering/shaking you feel when at light throttle inputs.
I am dealing with a particularly severe case of the 0300's. I get that stutter like 4-6 times each day on my 10 mile commute to work.
I have to operate the throttle like it is an on-off switch if I want to avoid getting the error....but it is just not appropriate or safe to drive this way in fairly heavy freeway traffic.
Mitsu apparently has a fix on the way for this problem in the way of an ecu reflash. Over the past 6 months I have heard countless people saying that the fix will be here shortly.
SC~
This is not correct information.
SC~
SC~
possibly naive suggestion-- I'm not familiar with this issue.
**disclaimer** try this at your own risk.
but if the P0300 error is an overactive knock sensor has anyone attempted to dampen/isolate the sensor? generally they are threaded in, and you could probably insert a rubber or nylon spacer. this moves the microphone away and also isolates vibration.
Don't even try altering the signal of the Knock sensor for this is the sensor that keeps your engine from blowing up!! you don't want a silly ghetto fix to damage your $ 30,000 car. Fix it right.
I'd check my plugs first. maybe it's all carboned up. it's really hard for spark to travel if its all covered in carbon let alone in 19+ psi in the cylinders. replace them if neccesary. won't hurt to try .
um, under normal conditions a knock sensor should be doing NOTHING. get an OBDII realtime scanner-- there are many varieties around including fairly inexpensive "hobbyist" type units-- and SEE what it's doing.
it's not a fricken oxygen sensor or cam angle sensor. when the engine is running right, the knock sensor does diddly. if you have the stock exhaust you should HEAR detonation and get the hell out of the throttle, anyway.
and now, back to your regularly scheduled ill-informed flaming.
Umm.. I don't think his car is running normal. A knock sensor does something. It detects knock. It see's it all the time. If it detects to much, then it tells the ecu, then the ecu retards timing, ect.. to save the motor.
Just ask anybody that has a AFC II. Ask them how many knock counts they get while driving, even at idle.
before going too crazy, if you haven't already done this, put in a new set of plugs.. I'd get misfires all the time and similar symptoms to what your describing until I changed my plugs. Now it doesnt happen at all. Just my 2 cents.. before getting too concerned, its a cheap easy thing to replace your plugs. I put one step colder plugs but I also run slightly higher boost than stock.
