Evo running like #$%^
Old Jul 11, 2004 | 07:11 PM
Wizard_of_Evo's Avatar
i know it seems ctazy, but i had a very similar issue and that was the problem. above 5k the snorkel would be pused up to the hood and cut off air flow to the motor.
Old Jul 11, 2004 | 07:14 PM
KillaSweep's Avatar
the clips are fine....i just took the cover off the air filter and checked for anything abnormal and reseated it and replaced the clips just to be extra sure.
Old Jul 11, 2004 | 07:16 PM
MalibuJack's Avatar
Ok, what about the snorkle, not the top of the airbox..
KillaSweep's Avatar
is it possible the it could be the MAF? I just don;t get why it runs fine until it gets hot....maybe it is just a coincidence that is acts up after I have been driving for awhile...i'm clueless
NvsEvo's Avatar
just solve the problem by getting an exhaust system to free up more air......
Old Jul 11, 2004 | 07:17 PM
KillaSweep's Avatar
the snorkel being the part that attaches to the top of the airbox? that has the two little round clips?
not the airbox snaps - the snorkel retainer snaps that hold it down just in front of the snorkel opening.
Old Jul 11, 2004 | 07:18 PM
KillaSweep's Avatar
the exhaust will be coming soon...i just want to get it working right first.
Old Jul 11, 2004 | 07:19 PM
KillaSweep's Avatar
correct...i checked both....everything is bolted down...snorkel..and top of airbox
MalibuJack's Avatar
Something is probably cutting off the airflow to the engine.. or the BOV is leaking massively (Missing vacuum line to the DV or the DV is installed backwards..)
I suggest taking off the snorkle that goes into the airbox, not the cover, for short period of time to see if that is moving or blocking airflow..
Old Jul 11, 2004 | 07:21 PM
MalibuJack's Avatar
Anyway, I had a massive misfire for awhile on my car, replacing the plugs got rid of it.. However the symptom in my case wasn't anywhere near as predictable..
You could be experiencing fuel cut due to overrunning the MAF sensor, but that doesnt happen very often with the stock airbox still on the car..
Old Jul 11, 2004 | 07:22 PM
MalibuJack's Avatar
Do you have a boost gauge on the car? I wonder if the boost is dropping off severely or the engine is just cutting out..
Old Jul 11, 2004 | 07:26 PM
KillaSweep's Avatar
Yes I do have a boost guage...sometimes it reach full boost...but only before the weird engine cutoff thing starts happening.
If I was getting a bad misfire from fouled plugs or something would I be getting a CEL with a misfire code?
Old Jul 11, 2004 | 07:27 PM
KillaSweep's Avatar
oh yeah the dealership said that all the sensors were reading the way they should be too...they had the computer hooked up to it..even when they were driving. That's why he thought bad ground or wastegate syllanoid problems
Old Jul 11, 2004 | 07:30 PM
MalibuJack's Avatar
If it was a boost solenoid problem it would be either on or off.. which means your boost would go up or drop down, but you would see it fluctuate on your gauge.. you will not get a misfire code from fouled plugs.. boost induced misfire is basically cylinder pressure "blowing out" the spark.. It makes the car feel like its sluggish and losing power.. Fuel cut is a harsh "shut down" of fuel to the engine.. its not just a sensation of stumbling and slow acceleration.
