Wideband O2 Sensor
Wideband O2 Sensor
I was just curious too know the reason behind needing a controller for a wideband? Why can't you just buy a wideband (Bosch unit LSU4.2 or similar) and install it into the exhaust system. Then run a 12v power and ground too it, run the output to a meter or or other metering device to read the info and, if needed, use the stock heater wire to heat the wideband sensor?
I've thought of the same thing specially since I've heard rumors that Evos come with a wideband from factory (5 wire o2 sensors up front) but I haven't even looked at mine or attempted to start on something in regards to it. I had a little discussion with some one at plxdevices.com and they are under the same impression that the Evos come with a wideband sensor from factory.
But like I said this remains to be proven . If it was true though, all we would need would be a control unit and we would have a wideband!
Anyone have any input on this theory??
shunderwunder
Nov 30, 2007 04:11 PM
500whp.com
40
May 18, 2006 10:29 AM
