Where is the oil pressure sender
Im installing a oil pressure gauge but i cant find the pressure sensor in the engine bay. Can anyone direct me as to where it is? i feel like a fool, i've been looking for 2 hours.
I figure that it might be connected to where the oil filter goes on... That's where it is for the DSM's... Crazy4cars could be onto something.. I've never tried to look...
Well, like I said.. For the DSM's.. The sending wire is connected to the housing where you screw the oil filter onto... Should be a little wire and a clip... Maybe connected to a circular looking thingy.. That is all I got for ya Bud.. Good luck.. Post up so I can see if you found it or not!!
There are several ways to do it. Here's one https://www.evolutionm.net/forums/sh...t=oil+pressure
hmm.... that thread tells you where. It's right on the oil filter housing, above the oil filter. There are 2 ports you can use on the housing. Look on page 2 of that thread and it will give you the specs of the adapter fittings to use for mating up the the ports. You'll have to check what the specs are for the senders that you gauges use to mate with the adapters aswell.
Here you can see the oil filter(white), the oil temp(on the oil pan also double up as a drain plug) and oil pressure sender above the oil filter.
thanks for all your help but i still cant find it in the engine bay. I took out the battery and the battery tray and the airbox but i still cant find a damn thing. Its been the whole day now and I'm stuck with jack **** done. Sorry guys i just dont get it, thanks for the help. I really want to get this installed.
are you kidding me. someone please ban me from this site. i spent 7 hours trying to find the oil thingie when it was on the wrong side. thanks for being patient with me. i Know, im a dumbass
