4th Gear 5k - 7k RPM Shifting Grind
I need to know if any of you guys experienced the 4th Gear Grind 5k - 7k rpm range?
It only happens when you go WOT from 1st to 2nd to 3rd and when it hits 4th at around 5k - 7k rpm it always grind, no matter how hard I floor the clutch it still grinds?
But when you wait 1.5 seconds when you put it in 4th it doesnt grind?
Regular driving it doesn't grind either, only when you shift fast to 4th at WOT it grinds all the time.
Is there a solution to this problem? Any suggestions or tips would be greatly appreciated.
Thanks
Thanks
Thanks
Thanks
Appears as if the clutch is going bad and preasure plate is not releasing. I think you need a new clutch.
my 4th gear is the only gear i've had grid too. and i've only had my car (and clutch) for 3k miles.
i think that it's because the 4th is the most closly ratioed gear - it's just tough to hit it just right.
snoop,
I only have 7k on the clutch, and I don't launch the car at 4k and above. Never Drag Raced it and pushed it hard.
evolute,
Do you think we have a solution to our problem? Maybe changing the clutch fluid?
What do you guys think? Any tips?
evolute,
nah you prolly have what is NOT a rare issue from what i can see with the evo...
bad 5th gear syncro... it happened on my car.. only it would happen even with a normal shift.. it started though with a higher rpm.
dealer covered it- apparently there is a bulliten out about 5th gear syncro goin bad
take it to your dealer and get it fixed.
Adjust your pedal out.. It will help the disengagement .. I had this same problem, after i did the pedal adjustment things were MUCHHHH better...
Its located right where the pedal meets the firewall. A little 10mm i believe wrench, loosen the nut, grab the metal twig like screw part and twist to the right, then tighten the nut.. Should help some.. worked for me
I've had the 5th gear grind too, but after time it went away now its in 4th gear, do you think with regular driving it will go away too?
Any Mitsubishi Service station that will not harass you in the mods done to your car?
Located here in Los Angeles area.
I JUST had that problem today actually. I don't know if it was only a today thing...but I was jamming on it hard to pass 7 cars and a semi...I could NOT shift into 4th. I also have the 1-2 grind since day one...and they swear nothing is wrong with it...and in the last few months I have begun to develop the 5th gear grind above 4500 rpms
