running richer in higher gears... cause of load points?
Originally Posted by rt turbo
i use lm1 with the bosche 5 wire. it reflashes every .4 seconds it says. i use emange to tune.
the refresh rate is not fast enough to register the particular rpm AFR that you want.. Both the Bosch and the NTK is still too slow..
By the time it reflects the AFR, what you see is probably about 500-1000rpms ago ..
Originally Posted by gunzo
Think that sorta answers my questions ..
