Intake swap with reflash??
Old Aug 12, 2004 | 05:31 PM
smokey's Avatar
Exclamation Intake swap with reflash??
This probably has been discussed, but I can't find the threads for it. I have a k&n typhoon intake with a reflash, and it seems to run fine....a little rich but runs fine. I was thinking of putting my stock intake back in just because of the problems I have heard with the typhoon.
The question is should I put the stock box back in, even though I have had a reflash with the typhoon intake?
Will I see better performance out of the stock box?
Will I hurt the car by not reflashing again with the stock intake?
Any input would be helpful.
Old Aug 12, 2004 | 06:10 PM
nrcooled's Avatar
If your running rich now you will be running even more rich (is that a word?) after you put the stock box back in. This is assuming that your ECU is flashed for your curent mods. The stock box will pull in less air hence you will be slightly richer. The MAF should adjust accordinly though.
Old Aug 13, 2004 | 10:30 AM
smokey's Avatar
Would this hurt the vehicle though? running too ruch can be bad, right??
Old Aug 13, 2004 | 11:18 AM
TampaTurbo's Avatar
all you will do is fowl your plugs and may smell gassy when you get out of the car if you are driving with your windows down....gassy...LOL
I have the same filter, It runs fine. I am not goingt to touch mine unless my future mods cause any problems.
Old Aug 16, 2004 | 09:41 AM
smokey's Avatar
Hey Tampa Turbo......what whp are you running with all of your mods.
Mike Barczynski
Jan 10, 2016 06:06 PM
Hotevo3
Cobb AccessPORT
Mar 27, 2014 10:23 AM
deegaw11
Nov 13, 2007 09:04 PM
i8urvtec
Nov 27, 2006 07:21 AM
gunnerman
10
Oct 31, 2005 06:00 PM
