Buschur upper intercooler pipe hose to intake
Old Aug 12, 2004 | 06:34 PM
rpm-evo's Avatar
Question Buschur upper intercooler pipe hose to intake
I just got my Buschur upper intercooler pipe kit, with the g1 diverter valve. The question is the stock tubing from the stock pipe to the diverter valve to the intake does not look like it will reach on the Bischur setup. What kind of tubing do I need and where can I pick some up? I plan on putting it on this weekend, and would like to just grab the tubing to run from the DV to the air intake. Is this just radiator tubing? All that came with the kit was the two pieces of tubes, the g1 DV, and a few clamps. Is there anything else I need? Vacuum hose?
Old Aug 12, 2004 | 07:27 PM
JustDSM's Avatar
Do you have the Buschur compressor inlet pipe?
Old Aug 13, 2004 | 11:22 AM
rpm-evo's Avatar
No,
I just have the buschur upper intercooler kit. I currently am running the K&N typhoon with a forge DV. That used the stock tube from the intercooler pipe to the DV, and then from teh DV to the air intake pipe. The buschur kit places the DV right on the intercooler pipe almost next to where the air filter is. So I need to run some type of tubing from there to the intake pipe. What kind of tubing can I use?
Old Aug 13, 2004 | 11:25 AM
Guack007's Avatar
Call BR. Those guys are very helpfull and usually friendly
Old Aug 13, 2004 | 11:50 AM
TampaTurbo's Avatar
Let me know what happens. I ordered the kit and have the exact same set up as you. I forwarded Jarrod a picture of the DV and told him it goes in the same place the stock DV was. I will not know if that makes a difference or not.
Old Aug 16, 2004 | 08:13 AM
Jrod@Buschur's Avatar
You said you are running the K&N Typhoon system correct? Is the stock Intake pipe still in tact and you just have the filter or how does that intake work?
I got your email but it had no picture attached to it. Try to put it up here so I can look at it. thanks
Old Aug 16, 2004 | 08:43 AM
TampaTurbo's Avatar
Thumbs up
Hope this helps. just click the link. http://www.forgemotorsport.com/valve...duct=FMDVEV015.
Scroll down to FMDVEV015 for Mits EVO.
I sent the pic to you before but I cant get it to show up in this box.
Old Aug 16, 2004 | 08:47 AM
How does the K&N intake work tho? Is it just a filter or does it replace the pipe as well?
Old Aug 16, 2004 | 08:55 AM
TampaTurbo's Avatar
Smile
The Typhoon intake replaces the stock inlet pipe with its own. It also has a CF heat shield that fits behind the filter to help keep out heat. That shouldnt affect the IC pipe though. I wish I could see a picture of an engine bay with your Upper IC pipe then I can tell you exactly what might be the problem. Shhheesh, exactly what might be.... lets make that a good guess!
Old Aug 16, 2004 | 09:06 AM
91GSX's Avatar
do you need a pic of an evo with the upper ic pipe on it & stock intake pipe as reference? i can run out real quick & post one. jarrod just sold me one over the weekend & we threw it on at the campground. (jarrod, thanks again for helpin get rid of the gauge pod)
Old Aug 16, 2004 | 09:09 AM
TampaTurbo's Avatar
here is a pic of the typhoon. http://kandn.com/images/l/69-6543TS.jpg
Old Aug 16, 2004 | 09:11 AM
TampaTurbo's Avatar
Yes a close up pic of where the turbo inlet pipe and Upper IC pipe meet in relation the stock DV. You know, that general area. Thanks
Old Aug 16, 2004 | 09:12 AM
91GSX's Avatar
k gimme a few...
Old Aug 16, 2004 | 09:28 AM
91GSX's Avatar
here ya go man, four pics of that area. hope this helps. if you need a pic of anything other than this let me know.
Attached Thumbnails Buschur upper intercooler pipe hose to intake-icpipe.jpg   Buschur upper intercooler pipe hose to intake-icpipe2.jpg   Buschur upper intercooler pipe hose to intake-icpipetoinlet.jpg   Buschur upper intercooler pipe hose to intake-icpipetoinlet2.jpg
Quick Reply: Buschur upper intercooler pipe hose to intake
