Tomei PROcam 270
I have Tomei procams on my Evo. The duration is 260 degrees not 270. The high lift necessitates upgraded valve springs and retainers.(I used Ferrea titanium) I am very impressed with the Tomeis, but you need the usual supporting mods to get the full benefit of any cam upgrade.
We dynoed 493whp on a Greddy T67-25G, pump gas, and Tomei Procams... 25psi and small water/methanol shot. Very safe tune, because it is a road race car.
George
Actually the Tomei Procams now come in 260/270/280 degree durations
Originally the 260 was the only option and the only one listed on their site. But they now stock 270 and 280 where previously they had t be specialy ordered.
From what I undertand though ( and I could be wrong ) The 270/280 cams are more suited to strokers and /or those running past the stock redline.
Cheers
Cheers
Cheers
I want my car as a daily driven one, occasional track use. i'm surely not into drag
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
![Talking](https://www.evolutionm.net/forums/images/icons/icon10.gif)
Originally Posted by med50081
Yes, tomei indeed now stock cams for all 3 different durations. Personally, am thinking of either the 260 or 270 procams. I wonder if the low to mid range would suffer more for the 270 compared to the 260.
can't decide which cam to get ?!!
It is perfect for a stock engine as you lose almost nothings downlow but gain alot higher up. ( higher boost then stock will reap more gains)
I have tried a mates car with the 270 cams in and I feel that the power band has shifted up a bit and peak power is a little beyond the stock redline.
If I was planning a big turbo or stroker, I am sure that the 270s would be on my mind.
dun quote me on this bit but you are correct tin saying using cam gears will give you some flexibility to move the power band around but IIRC you get better response at te expense of top end power. You are not actually makeing the power band wider. Even in the case of a 260 cam , you can use the gears to get alittle less response and a litle more top end power. I suppose you can ask if you want more mid range torque or more top end power.
Have you thought about Piper 265 degree cams with 11.5 lift?
so you may end up with the equielant of a 260 cam....
but if your intention is to get a bigger turbo or stroke the engine at some later date then it may make sense.
Scottr126
Dec 23, 2008 10:57 PM
Edo Performance
17
Jun 21, 2007 12:21 PM
500whp.com
19
May 12, 2006 06:11 AM
