Before I cut the vac line for the boost gauge
The how to for the boost gauge install isn't showing the pictures so I want to make sure I'm tapping the vacuum line at the correct spot. Is this line with the wire loom coming off the fpr where to tap? TIA...
Originally Posted by rburris28
The one coming directly off the fuel pressure regulator wrapped in your photo with the plastic loom is the one I used. It has worked since February without a problem, and reads 19.5 psi peak, 16 psi redline.
What line are you talking about over the manifold cover? Do you have a pics? Why not the fpr line? Thanks a ton...
PHiSH
I thought the fpr was the most constant place.
PHiSH
PHiSH
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
Originally Posted by gtr
If you ever drive aggressive your boost will sometimes read zero, when the FPR does it's stuff
. Use the one from the mainfold on the other side ![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
Originally Posted by EVOTEXAS
Maybe with a faulty install,
![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
Originally Posted by BaLListic_EVO
here are some pics with easy to follow bright yellow arrows........... this is where i was told to install and it keeps a good solid reading here.... ![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
That is where I decided to relocate it to. Seems to run perfect for almost a year and have not have the problem since.
I installed my Defi boost gauge according to the directions and it said to tee it between the manifold and the FPR solenoid. That is the short hose (4" or so). I tapped it there and no problems. I've heard others say they get inaccurate readings if they tap after the FPR solenoid due to the fluctuations.
Blue Evo 8
14
Jul 10, 2005 06:22 AM
titaniumkingpin
Sep 10, 2004 05:01 PM
schleppy
Jun 30, 2004 02:25 PM
