clutchmaster stage 3
anyone have any input/opinions on this clutch?
it seems i cannot shift quickly into 3rd without a grind or missing the shift.
not for regular shifts, but higher rpm or quick shifts.. some have told me that the clutch is not disengaging fast enough- therefore it either misses or grinds..
is this a problem with the clutch or are my synchros shot?
i did that have that issue with the 5th gear syncro grinding, but they fixed that....apparently...
if anyone has any experience with this clutch, it would be greatly appreciated.
also- do you think the stainless steel clutch line willl improve this at all??
hmm interesting..
if im gonna do the stainless steel clutch line, what do you re-fill it with? brake fluid?
also- do you think that i should change my tranny fluid to something else? would that help the notchiness or grinding thing??
Wht9er
14
Sep 16, 2009 06:20 PM
