"Optimal" Fluid Combo !?!
My head is killing me from all the posts I've read using our beloved (pos) search function, but he's what I've boiled the info down to "Optimal" being the key word here; not prefferential, recommended, etc.:
1) Transaxel Fluid - GL4, 3qts., 75w90 (MT 90 Penz Syncromesh)
2) Transfer Case - GL5, 0.58qts., 75w90 (RedLine 75w90 NS) no LSD frict. addtv.
3) Rear Differential - GL5, 0.58qts., 75w90 (AMSoil Series 2000 75w90) LSD gear
oil with friction additive
Transmission - Penzoil Synchromesh -AutoZone carries it
Transfer Case.. Go with Redline Heavy Shockproof gear oil (Warmer Climate) Light Shockproof (Colder climate)
Rear Diff (Amsoil is good but even easier to find is Mobil 1 75w90 Works JUST as well.. Good stuff)
These are Optimal Fluid Combos. Everyone has their own combo.. But from adoing a LOT of research and calling a lot of tuners. This has been what I found is best ..
Tranny - 70-30 mixture Redline MT90 and Penzoil Synchromesh
Transaxle - Shock proof is good
Diff - Don't know enough about but a LSD has little clutches inside it and I would think full synthetic would be too slick and thus not allow LSD to work optimally. Clutches will slip too easily and would cause premature wear. Just my uneducated theory. Don't take it for fact...
Originally Posted by SinCityEvo
Tranny: GM or Pennzoil Syncromech
TC and rear: Mitsubishi Diaqueen LSD gear oil
Amyone?
There are different kinds of diffs. I don't think the stock diff has clutches. I think as the fluid heats and thickens, it creates the diff action. Aftermarket diffs have clutches in them because they can handle more power.
Why would you want a 70/30 mix? We are talking 3 quarts of fluid. Are you sure that 72/28 mix wouldn't be better?
Originally Posted by 4-BNGR
Diaqueen from Mitsu comes by the gallon at $50 buck a pop
royal purple max gear 75 90 in front and rear dif
royal purple syncromax
i had great results with this combo.......lol just dont launch the car and you wont break it
Do the tranfer case and rear lsd oils mix with one another? If so, should we not use the same oil for each (implying one that has a friction additive as required for the lsd)???
BG Syncroshift. GM/Pennz syncromesh combo
Diaqueen for TC & Rear Diff.
