What to use for intercooler water spray?!?!
Old Nov 2, 2004 | 08:58 PM
J8dailo's Avatar
ya..another dumb question...my waterspray is empty...i know some people put water in it..and some put water/alcohol in it...so im not really sure...just want the best for my car...advices??
Old Nov 2, 2004 | 09:01 PM
bluebanana23's Avatar
It all depends on where you live. Use wiper fluid if you live in colder regions or just plain water will do but algae may form so spray often if you use straight up water.
Old Nov 2, 2004 | 09:02 PM
NAICHE's Avatar
dude, read your manual!
Im pretty sure it says to use a 7.2-9.5% microbrew ESB or IPA.......Goodluck!
Old Nov 2, 2004 | 09:08 PM
J8dailo's Avatar
i read it...i live in midwest region...it get cold during winter.. the manual said sumthin like " fill the reservoir with windowshield antifreeze, and operate the system for a few seconds to "flush out the residual water".
thats the only thang is found...mmm...so does that mean water? or windowshield antifreeze??
Old Nov 2, 2004 | 09:14 PM
Richard EVO's Avatar
I live in SoCal, where it never snows, and is 100 degrees in the summer. What should I use? Thanks.
Old Nov 2, 2004 | 09:17 PM
EvoTio's Avatar
I've been using distilled water here in So Cal.
Old Nov 2, 2004 | 09:22 PM
J8dailo's Avatar
over here it gets down to as long as 10 degrees in winter..sumtimes even lower...
Old Nov 3, 2004 | 12:29 AM
evolved04's Avatar
if you arent worried about freezing then use distilled water. the only reason the manual says windsheild fluid is because it has agents to keep it from freezing. the only bad thing i can see with that is it would burn your spray motors out while trying to spray ice. there is even room in the neck, 5 inches above the drain, to let the ice expand. my .02
Old Nov 3, 2004 | 12:31 AM
Sentinal's Avatar
a better question is does anyone actually use them... I tried mine but didn't see any diff so it pretty much is a feature that sits and does nothing...
Old Nov 3, 2004 | 09:40 AM
Ted B's Avatar
Methanol / Water (washer fluid) does a better job of cooling than water alone, and is less prone to freezing. Distilled water is a viable substitute if you are too lazy to get washer fluid, but it may freeze. Tap water should never be used. It contains mineral impurities that will foul the spray nozzle and/or leave scaly deposits on the intercooler.
Old Nov 3, 2004 | 11:57 AM
plokivos's Avatar
use It'll get your IC to fear nothing and make other IC look better.
Old Nov 3, 2004 | 05:47 PM
rburris28's Avatar
I still don't get this. Since the intercooler is wet by dirty water from the street when it rains, what difference does tap water from the sprayer make? Has anyone actually seen this to be a problem? Any clogged nozzles out there?
I think the sprayer only works on long grades (or racing) in high temperature/low humidity situations anyway.
But's it's fun to push the button!
Old Nov 3, 2004 | 05:51 PM
plokivos's Avatar
bleach and all the chemicals that's in the water for purification reasons...
I don't see any problems with the tap water. Alcohol and water mix seem to work good, but I heard it really doesn't do much at all for the air being colder.
I think it's because the IC piping (the rubber part) that's going to the Throttle body is right under the Down pipe, so the air gets warm anyway.
Old Nov 3, 2004 | 06:07 PM
zlancer's Avatar
Methanol and ethenol corrode (or increase oxidation rate of) aluminum. just a thought.
Old Nov 3, 2004 | 06:51 PM
plokivos's Avatar
I heard people are running alcohol gels now. they'll just smear it on the IC sprayer before they run and by the time they're done, it's gone.
They cool faster and heat slower.
Quick Reply: What to use for intercooler water spray?!?!
