Hydra Nemesis 2.0
for people who need to know what this is, it's
http://www.hydraems.com/ems-index.html
Dual 16bit 25MHz Processors
Plug and Play
Windows programmable Software w/ Direct Serial cable Connection
Uses All Factory Sensors (Might need additional sensors, e.g.: 1990 to 1993 Miata will need air temp sensor and knock sensor)
Retains all factory functions
· EGR
· Purge Control
· Power Steering
· Coolant and AC Control
· Factory Intercooler Spray, EVOVIII and Sti
· Air Conditioning
· Boost Control
· Idle Speed ( Both Solenoid and Stepper Types)
· Cold Start Compensation
· Acceleration and Deceleration Enrichment
· Wideband )2 Air/fuel Long and Short term Control
· Programmable Closed Loop Knock Control
· Check Engine Light Control
· Backup Spark tables for Limp mode
Fuel map 32 by 32 grid styled
Ignition Map 32 by 32 grid styled
Two Mappable Variable 3D Cam Maps 24 by 24 grid styled (VTC/AVCS/VVTi/Vanos) Closed Loop true cam timing by degrees Soon…
Aux 3D Fuel Map 32 by 32 Grid Styled with switched input (For Dry NOS or Race Gas)
Aux 3D Ignition Map 32 by 32 Grid Styled with switched input (For dry NOS or Race Gas)
*3D Antilag Fuel Map 32 by 32 Grid Styled with switched input
*3D Antilag Ignition Map 32 by 32 Grid Styled with switched input
built-in 3 bar map sensor replaces all MAF or AFM with Speed Density for up to 30psi (up to 45 psi with optional 5 bar map sensor)
Full Sequential Fuel injection and Ignition control for up to 8 cylinders
Drives all types of injectors without the need of a ballast box (peak & hold and Saturated)
Individual Fuel Injector Trim
Injector Phasing
Wide Band Closed Loop Lambda Control for true Auto mapping of Air / Fuel 32 by 32 Grid Style (requires Optional software upgrade and NTK L1H1or L2H2 Wideband Oxygen Sensor)
Continuous Closed Loop Air / Fuel Correction 32 by 32 Grid Style (requires Optional software upgrade and NTK L1H1or L2H2 Wideband Oxygen Sensor)
Tachometer Drive
Coolant temperature and Air Temperature correction for Fuel and Timing.
Barometric Compensation for normally aspirated cars(with optional 1 bar map sensor)
*Antilag Control
Soft-Cut Rev Limits
Boost Limit
Electronic Boost Control
2-step launch control (Switched Input)
Definable Knock Control (two setting amplification with definable threshold) with adjustable fuel compensation.
Backup Spark map strategy when excessive lean condition or detonation is detected
Limited Onboard Data logging (Unlimited data logging through PC)
Password Protection for Intellectual Property
Many Programmable 2D outputs (Staged injection, intercooler spray, water spray, turbo timer, shift light, VTEC, fuel pump, etc...)
$1600 MRSP
Hydra EMS America
c/o Quantum Performance Development
6167 Jarvis Ave #207
Newark, CA
94560
Tel: 510-870-1550
Fax: 510-870-6381
Carmodifications@aol.com
Plug and Play
· EGR
· Purge Control
· Power Steering
· Air Conditioning
· Boost Control
Injector Phasing
Tachometer Drive
*Antilag Control
Soft-Cut Rev Limits
Boost Limit
$1600 MRSP
Hydra EMS America
Newark, CA
94560
Tel: 510-870-1550
Fax: 510-870-6381
Originally Posted by MalibuJack
Thanks, you just posted what I was just copying to post.. LOL I want this to be my next toy to play with (On a different car powered by an Evo drivetrain)
as far as I know the hydra element for the evo 8 has only been available for a month or so. I am still waiting for a tuned version to be developed for my evo. For someone like MJ who will tune his own (and if he can get to the front of the line) it should be available.
So far they have been developing the suby version, but I am told work is being done to get a tuned evo version out soon.
http://www.elementtuning.com/main.htm
I don't know if it is available elsewhere.
Originally Posted by gestalt
Sounds like an interesting project. What kind on car are you puttin an EVO drivetrain in?
This is the project thread.. Hasn't "gotten launched" yet, just lining my ducks up..
Definitely has a bunch of "Desirable" features that i've seen in the Autronic, and the AEM EMS, plus a few features I haven't seen yet in any EVO targeted EMS..
I'm really tempted to run this in my Evo for some time to learn how to use it and get it set up for my project car.
Has anyone gotten one for a USDM Evo 8?
I would like to get one to test out..
Hi There
I'm using the hydra nemesis on my evo8. So far so good. I'm not a tuner so I had to get someone to tune it for me. If you're intrested, give andrew a call. This ecu has more exposure in the wrx market.
Ben
I just got an e-mail reply about it yesterday, I was told they are still "mapping" it and shelved it until they can finish the WRX/STI version.. I'm not sure if that was the manufacturer's comment or this particular distributor of the product... Who did you get yours from? Since i plan on mapping it and programming it myself, I don't really care about a base map other than it starts the engine..
