Boost controler
Boost controler
Should i stick with the manual and just get a gauge or should i go with electronic please help money is no issue for this i need to get the best on the market which option is better and what would u guys recommend i order thanx
if money isn't an issue, get an EBC and get someone to set it up properly for you. EBC's have better control over boost and it's constantly monitoring so things like boost spikes aren't an issue. although most decent MBC's are pretty good, the answer to your question as far as which one is better, it's the EBC.
I have a Greddy Profec B spec II. Once I figured out how to properly set it(with help from this site, mainly AL) it works perfectly. You will need to adjust it very slightly with weather changes, but it holds steady like a rock. I could'nt be happier with it.
Originally Posted by JohnnyTwoThumbs
I have a Greddy Profec B spec II. Once I figured out how to properly set it(with help from this site, maily AL) it works perfectly. You will need to adjust it very slightly with weather changes, but it holds steady like a rock. I could'nt be happier with it.
A hallman has worked for years since day 1 back in 1990 and that is all u need $90 keeps u where u want to be. for the price of an ebc with install u can get a lot better more hp parts on the evo....
I have yet to see any electronic boost controller that does not spike, are they good? yes.
worth the money? no.
A boost gauge from autometer is less than $60
But then again, the choice is yours........that is why there are so many couple of hundred dollar ebc's out there.
I'm telling you what works good enough for the 10's and is under $100.......set it and go
hmm my Blitz doesnt spike at all. You can basically set it and forget it, you might only have to change it if the temperature is real cold out, other than that you can set it and forget it. It also makes it nice to be able to adjust it within the cabin, for days when you feel like running your 100octane race map and want to up the boost a few psi!
Also, if you like the Greddy Boost controllers, take a look at this Dyno....
This is an Evo using a Profec B Spec 2, the car was left on the dyno and the E-boost was installed. Less than an hour passed. The same boost levels were run, notice the same peak horsepower. But since the user can select when the wastegate starts to receive boost, using the gate pressure settings. The car will build boost quicker and have more power mid-range.
