brake grind/sqeek
brake grind/sqeek
ok well i just installed mky exhaust the other day and i know my brakes are very very bad. ordering new ones this week actually.. but today i'm driving and it sounds ike i'm dragging a rake under my car.. it makest his annoying grind and a sqeek ( not at the same time, but its either one or the other.... should i be worried about this grinding or sqeeking?? or does the evo have some kinda of sensor thing on the brakes for when its low on pad it makes noise?? any feed back would be appricated
YES STOP DRIVING!!!!!!!!!!!!!!, the squek is from the warning tab on your pads, and the grinding is the posts of the pads, grinding into your rotors!!!!!!!!!!!, if you keep driving, instead of just resurfacing your rotors, you will probably need new ones and they always suggest you change them in pairs, unless you want to upgrade to slotted rotors!
You have probably reached the wear indicators, which make this horrible squeek which gets louder and louder. I am not sure about the EVO, but when this happened on previous cars I have owned, it wrecked the rotors pretty bad. This was after drivng for several months with the noise. If you can refrain from driving till you get new pads and the rotors turned, the less damage you will do.
