Take a guess!
#33
Originally Posted by tke_413
Does not having a cat make your car stink when you floor it?
At MZM they use 14.5 hp at 50mph at 3400 lbs.(+/-) vehicle wt. and I make about 260hp. At Wasabi I made like 299hp. Both have Mustang Dynos, just use different set-ups.
Do you know what they use at FIS?
#35
I have no idea
Nothing like a 40 hp swing on two of the same dynos to snap you back to reality.
You should really only look at dyno numbers as a basis for how you have improved your car. Not who's got what big numbers. I'm not saying this how you perceive dyno numbers, just presenting a way to keep it real.
#36
I had my base dyno done at FIS though, so I'll just keep going back there when I'm curious about MY numbers. I think the only real way to believe dyno numbers are to use the same one all the time, and only compare to other cars who have used that same dyno.
#37
Any more last minute guesses on what WHP i'm gonna put down at 5pm...here's the mods again...
Injen Intake with upper i/c piping
Hallman MBC set to 20 psi
Iridium spark plugs
Nology Hotwires
Megan 3" Downpipe
Megan 3" High-flow cat
Helix 3" cat-back
Walbro Fuel Pump
MR Diverter Valve
TurboTrix custom flash/tune at 93 octane
Iridium spark plugs
Nology Hotwires
Megan 3" Downpipe
Helix 3" cat-back
Walbro Fuel Pump
MR Diverter Valve
#41
Originally Posted by GS_Turbo
im not saying you dont feel n e thing, i know that you do, but u not 20hp, MAYBE 20 crank. not tryin to be a dink tho
My mistake, I was thinking in crank hp, not whp. A test pipe by itself would definitely NOT add 20whp!
~fred
#43
The MD 7100 which is what we had was calibrated to be as close as possible to real world driving.
FIS has the previous version of ours and I am sure they are updated as well.
In my opinion if a EVO is laying down 300HP on a Mustang then be looking for 360-375 on a Dynojet. There are a lot of varibles in getting the same number.
- You car maybe sitting in the shop and the motor as well as tires are the same as the ambient temp.
-Ambient temp and humidity is also a big issue.
-Fans and cooling on the car is also a factor.
-Rolling drag on the dyno
Basically it's a small glimpse of power at a certain time. On a dyno day ( driving the same type of car over and over) you may see 3 different numbers on 3 different pulls.
It's merely a gauge; to some degree a platflorm so you can say what power is what when changing diffent mods or progamming on the ECU. I am no tech, this is just experience from what I have seen and heard from very trust worthy sources.
Good Luck
Good Luck
#44
Don't I HAVE to keep the cat or get a high-flow? If i get the test-pipe and get pulled over...i'm screwed!
i would say almost all of the time you will not get a cop that will get on his knee's and look under your car...if anything you might get a $40 ticket for having a "loud Muffler"
