Take a guess!
Take a guess!
Alright, so with TurboTrix coming here on the 11th, I was just curious what HP/Torque numbers people think I might put down on the Mustang Dyno at FIS. It's an '04 RS with the following mods...
Injen Intake with upper i/c piping
Hallman MBC set to 20 psi
Iridium spark plugs
Nology Hotwires
Megan Downpipe
Megan High-flow cat
Helix cat-back
Walbro Fues Pump
MR Diverter Valve
Getting TT to do a custom flash/tune at 93 octane
I'll post the numbers on the 11th, but I'd like some opinions...I know every EVO is different and they all put down different numbers. Let's just see who get's the closest!
Iridium spark plugs
Nology Hotwires
Megan Downpipe
Megan High-flow cat
Helix cat-back
Walbro Fues Pump
MR Diverter Valve
Iridium spark plugs
Nology Hotwires
Espelir Downpipe
JGT500R cat back
Iridium spark plugs
Nology Hotwires
Espelir Downpipe
JGT500R cat back
stock cat high flow cat or test pipe?
blackevovii has same setup basicly - the upper ic and he has test pipe on TT's dyno put down i beleve 314 to the wheeles
so ya should be around that ball park
maybe a perrin cat delete pipe? this will complete the exhaust mods and you'll get a few more hp.... your biggest jump besides turbo will be cams + gears... so i wouldn't expect anything over 330 whp with every bolt on you can buy.... this is realistically...
stock cat for now. The reason i don't have THAT much done for performance is because I started out with the interior of the car. Added power windows/locks with door panels, center consol with armrest, visors with mirrors, gauge pod, dvd screen, JL speaks-amp-sub, and wing. now that i'm about done with the RS conversion...i'm ready to make it faster.
nice.. with stock cat probably puttn round 290 - 300 maby little less that should be at the wheeles i dont rember how the diff dynos run but that was on the dyno that TT has in their shop
Don't I HAVE to keep the cat or get a high-flow? If i get the test-pipe and get pulled over...i'm screwed!
Personally, I would rather remove my cat and then lobby Congress for sanctions on chemical plants, etc.
