What more do I need to net 350whp on 93octane?
Okay so here's what i'm looking at getting so far... (someone correct me if I'm wrong)
- ARP headstuds
- HKS Downpipe
- test pipe
- HKS Cam gears
- Lower intercooler pipes
If I get those things, will I be good to go?
Btw, here's what I have already:
- HKS Hi-Power 2.95" catback exhaust
- Greddy Type-S BOV
- HKS 264/264 camshafts
- HKS RS Intake
- Walbro 255lph fuel pump
- Greddy boost controller
- APEXi S-AFC II
- ARP headstuds
- HKS Downpipe
- test pipe
- HKS Cam gears
- Greddy Type-S BOV
- HKS RS Intake
- APEXi S-AFC II
You will need a Walbro 255 fuel pump.
I have HKS rs intake, HKS dp, Perrin test pipe, HKS carbon-ti, HKS 264's, Hallman set to 21 psi, Walbro 255, and a DynoFLash custom street tune.
I'm thinking of going with a 02 housing of some sort and a bigger dp since the car is breathing better now. I also plan on getting some lower intercooler pipping as well sometime down the road.
I don't have head studs. From what I understand you won't need them unless your going higher than 21psi. I don't run race gas in my car so 21 psi is the max I will run. I've seen that you really don't need cam gears as well with the 264's. Your probably like me....by trying to get as much power out of the stock set up as possible and trying to do it without buying stuff you don't need.
From what Al told me while tunning my car he said that my set up is or should be good for at least 330 to the wheels.
I"ve been thinking of dynoing my car so once I do I'll post and let you know.
Al told me my car "should be worth 290+ to the wheels" when he tuned me based on his butt dyno. It was 255 AWHP.....
