Seat-belt warning tone...
thats y they invented the seatbelt law...
if ur not smart enough to wear one .. then ur not smart enough to drive a car
a law that balances itself out with head through windshields
There should be two wires coming out of the bottom of the receiver, connect them together, no more warning. But please, due wear you seat belt, your car can be fixed in a couple weeks, you cant.
thanks so much for all the replys, guys . the reasons i ask is not i want to die, just worry about how can i wear 4points and the stock together as i just got my evo 2weeks ago and working on the car for next season. i vote for safe drive all the way, that's y i go auto-x and tracks
warning sound goes on no matter what after you move the car and the car has been on for 60 sec. i don't think you have to connect the wires. usually you havve to disconnect the seat belt warning @ plug that connects to seat. that is how i did it on my civic. i'll check later on under seat to see if it works.
Just unplug the harness under the seat. When the harness is plugged in with no seatbelt, the circuit is connected and signal get sent to the cluster that the seatbelt is not in and the warning light goes on in the cluster. Once the seatbelt is secured, it breaks the circuit and the warning light goes off. So unplugging the harness under the seat is the easiest way to get rid of the seat belt warning light as well as the noise associated with it.
